Grid Properties
Use the Grid and Image > Properties menu option (GRIDSTAT GX) to report and modify information about a grid, including simple statistical information and coordinate system information.
Grid Properties dialog options
The Grid Properties dialog is designed as a "wizard" that presents information depending on what you want to see or do.
Grid Properties - select a file
The first dialog enables you to select the grid file that you are interested in:
        Grid  |
        Select the grid file to report.  |
        Next>  |
        Select this button to display basic grid information together with options to see other information or to change certain information. The Grid Properties dialog will be displayed.  |
Grid Properties - grid information
All basic information about the grid is reported. The information displayed in this dialog is used to locate the grid in a real coordinate system. To make any changes to these parameters, click the Modify button.
        Grid  |
        Displays the name of the grid  |
        Grid element type  |
        Displays the grid element type (e.g., FLOAT, SHORT, DOUBLE).  |
        Grid points in X direction  |
        Displays the number of grid points in X direction.  |
        Grid points in Y direction  |
        Displays the number of grid points in Y direction.  |
        X point separation  |
        The separation between grid points in the grid X direction.  |
        Y point separation  |
        The separation between grid points in the grid Y direction  |
        Grid row orientation  |
        The grid row orientation (e.g., bottom left to right (KX=1)). For more information see Grids and Images.  |
        X location of the bottom left point  |
        The X location of the bottom left grid point in the coordinate system.  |
        Y location of the bottom left point  |
        The Y location of the bottom left grid point in the coordinate system.  |
        X location of top right point  |
                                                            The X location of the top right grid point in the coordinate system. |
        Y location of top right point  |
                                                            The Y location of the top right grid point in the coordinate system. |
        Grid rotation angle  |
        The angle of the grid in degrees counter-clockwise from the map coordinate system. Normally, this angle is 0.  |
        Coordinate system  |
        This displays the map coordinate system projection of the grid, if any. Click the Modify and then the CoordSys button to modify the coordinate system projection.  |
        Coordinate system units  |
        This displays the length units of the coordinate system. The grid origin and point separations are in these units. Click the Modify and then the CoordSys button to modify the coordinate system projection and units.  |
        Compression ratio  |
        The compression ratio of the grid file.  |
        <Back  |
        Select this button to return to the Grid Properties - select a file dialog.  |
        Stats  |
        Displays the Grid Statistics dialog, which presents basic statistical information about the data in the grid. You also have the opportunity to, re-calculate the grid, view a histogram of the data distribution, and view the removed trend coefficients, if any, from the Grid Statistics dialog.  |
        Modify  |
        Displays the Modify Grid Properties dialog, which enables you to change grid location and coordinate system projection information about the grid. See "Modify grid information" below.  |
        Exit  |
        Select this button to exit the grid statistics wizard.  |
        Select this button to retrieve Application Help information.  |
Grid Statistics
All basic statistical information about the grid is reported. The information labels are self-explanatory. The following table describes the function of each of the buttons.
        <Back  |
        Select this button to return to the Grid Properties - grid information dialog.  |
        Re-Calc  |
        Select this button to re-calculate the grid. For more information, see the [Re-Calc] Note below.  |
        Histogram  |
        Select this button to View a Histogram of the grid.  |
        Trend  |
        If a trend has been removed from the grid, this button will display the removed trend coefficients.  |
        Cancel  |
        Select this button to cancel the Grid Properties wizard.  |
The information displayed in this dialog is used to locate the grid in a real coordinate system. The information labels are self-explanatory. The following table describes the function of each of the buttons.
        <Back  |
        OK  |
        Select the OK button to accept your modifications to the grid properties, and return you to the Grid Properties - grid information dialog.  |
        CoordSys  |
        The CoordSys button will run the Coordinate System wizard, which
 enables you to view and modify the projection information. For more
 information about the Coordinate System wizard, click the
        Cancel  |
This dialog will only enable you to look at and modify information about a grid. No data contained in the grid will be changed.
Use the REGRID GX to change the sampled cell size of a grid.
Use the GRIDREPJ GX to re-project a grid to a new coordinate system.
Use the WARPGRID GX to warp a grid.
Metadata
Metadata (data about data) is captured by Oasis montaj from the first time the data is touched. The metadata information, which is based on ISO 19115 standards, is stored inside the data (if supported) or as a companion XML file.
Metadata (or Properties) are any information about the data. This includes; reports, survey parameters, projection information, or basically anything related to or that describes the data itself.
Modify Grid Headers
This GX can also be used to modify certain grid information in the header, such as grid location, cell size and map projection. It can directly change the grid header.
Therefore, it is possible to change the location of the grid on the ground and lose the correct ground registration of the grid. It is also possible to make the grid unreadable by setting header parameters to unreasonable values.
Script Usage
This GX can also be run from a script to report statistics and to modify parameters. Following are the scripting parameters:
        GRIDSTAT.GRID  |
        File Name of the Input Grid.  |
        GRIDSTAT.REPORT  |
        The name of a file in which to place a grid information report. "stdout" will report the results to the command shell.  |
        GRIDSTAT.RECALC  |
        "Yes" to force recalculation of grid statistics  |
        GRIDSTAT.MODIFY  |
        "Yes" to change the grid parameters as follows If changing grid parameters, all parameters must be defined, and if blank, only those that are defined will be changed.  |
        GRIDSTAT.DX  |
        grid X point separation  |
        GRIDSTAT.DY  |
        GRIDSTAT.X0  |
        X location of bottom left grid point  |
        GRIDSTAT.Y0  |
        Y location of bottom left grid point  |
        GRIDSTAT.ROT  |
        rotation angle (CCW) of grid X relative to map X  |
        GRIDSTAT.IPJ_NAME  |
        Projection information in GXF format. \"unknown\" should be entered as the IPJ_NAME to remove a projection. Set IPJ_NAME to blank to leave projection as is.  |
