X,Y to Longitude,Latitude
Use the Gravity > Locations > X,Y -> Longitude,Latitude menu option (GRXY2LL GX) to convert projected map or local coordinate system X/Y coordinates to longitude/latitude.
X,Y -> Longitude,Latitude dialog options
Conversion method |
Select the Projected coordinate system method to use a map projection. Select the Local coordinate system method to use origin and azimuth. Script Parameter: GRXY2LL.METHOD |
