Import Maxwell Plate File
Use the Imports > Maxwell Plate option (IMPMAXPLATE GX) from the Add to 3D menu in the 3D Viewer to import a Maxwell Plate model description file into the current 3D View. The file is imported as a 3D vector group that contains the plate models selected on import.
Import Maxwell Plate File dialog options
3D Controls (script mode only)
Viewing direction |
The viewing direction in degrees azimuth relative to the coordinate Y axis. Script Parameter: V3D.DEC (default 20.0) |
Viewing inclination |
The viewing inclination in degrees relative to the coordinate X-Y plane. Script Parameter: V3D.INC (default 25.0) |
Viewing distance |
The distance of the point of view from the center of the view relative to the size of the view. Script Parameter: V3D.DISTANCE (default 6.0) |
Draw bounding box |
Yes to draw a bounding box frame around the limits of the 3D View. Script Parameter: V3D.BOX (0:No (default), 1:Yes) |
Draw axis |
Yes to draw an axis with labels on the X, Y and Z axis. Script Parameter: V3D.AXIS (0:No, 1:Yes (default)) |
X title |
Titles for the X, Y and Z axis. Script Parameters: |
The IMPMAXPLATE GX can be used to import a MAXWELL program plate definition file into a new or existing 3D View. Up to 128 plates can be imported in a single file.
Currently, the first line in the file must be "MAXWELL PLATE FILE"; otherwise, the file will not be recognized.
MAXWELL PLATE FILETOTAL PLATES : 2
PLATE : 1
Use : YES
Attach to Tx. : NO
x : 4754.0000
y : 9277.0000
z : 1330.0000
Dip : -25.0000
Dip Direction : 0.0000
Plunge : 0.0000
Length : 100.0000
Depth Extent : 50.0000
c-t : 1500.0000
Skew : 1.0000
Ribbons : 20
Colour Red : 0
Colour Green : 255
Colour Blue : 64
PLATE : 2
Use : YES
Attach to Tx. : NO
x : 4816.0000
y : 9276.0000
z : 1255.0000
Dip : -27.5000
Dip Direction : 90.0000
Plunge : 20.0000
Length : 100.0000
Depth Extent : 100.0000
c-t : 5000.0000
Skew : 1.0000
Ribbons : 10
Colour Red : 255
Colour Green : 0
Colour Blue : 0
