3D Symbols
Use the 3D Symbols (V3DSYMB GX) to place coloured symbols on your 3D map. Symbols colour can be fixed or varied according to data values of colour data channel.
Display 3D Symbols dialog options
Elevation channel
The elevation channel name. Defaults to the current ‘Z channel’ of the active database.
If there is no current Z (Elevation) channel in the active database, the first channel from the list will be auto-selected.
The list contains all numeric channels with the exception of the current X and Y channels.
This option is disabled when the dialog is opened in edit mode.
Script Parameter: DISPLAYSYMBOLS3D.ELEVATION_CHANNEL
Mask channel
The mask channel name.
Select a channel from the drop-down list to act as a mask (or filter) channel. Only locations that have a non-dummy value in the mask channel will be plotted.
Script Parameter: DISPLAYSYMBOLS3D.MASK_CHANNEL
Shape
Select a symbol shape type from the drop-down list. Choices are: sphere, cube, cylinder, cone and dot. All symbol shapes except for the last (dot) create 3D symbols. Dots are best used for very large datasets (over 1 million points).
Script Parameter: DISPLAYSYMBOLS3D.SHAPE
Colour
Option
The symbol colour can be Fixed or Variable according to the selection here.
Script Parameter: DISPLAYSYMBOLS3D.VAR_COL (0:Fixed Colour, 1:Variable Colour, default "0")
Colour
The colour of all symbols if the Fixed colour option has been selected. To edit, click on the field and the Colour selection dialog will be displayed.
Script Parameter: DISPLAYSYMBOLS3D.COLOUR
See Application Notes below for a list of COLOUR values
Channel
If the Variable colour option has been selected, choose a channel to colour the symbols by.
Select a channel from the drop-down list to be used for the colour zones. The list contains all numeric channels from the active database. Disabled if the dialog is opened in edit mode.
Script Parameter: DISPLAYSYMBOLS3D.COL_CHANNEL
Colours
Select the colour scheme file for rendering the 3D symbols. If you mouse over the Colours field, a tooltip will display the name of the colour table in its folder. To modify the selection, click on the colour scheme, and in the selection dialog navigate through the colour scheme categories.
Script Parameter: DISPLAYSYMBOLS3D.COLOURTABLE
Method
The colour method to be used with selected colour scheme above. Defaults to Histogram equalization. Not available if the selected colour scheme file is of *.ZON or *.ITR type (in this case the colours are already attributed to data ranges).
Script Parameter: DISPLAYSYMBOLS3D.COLOURMETHOD (1: Linear, 2: Normal distribution, 3: Histogram equalization, 5: Log-linear)
Reverse colour distribution
Check this box to reverse the distribution order of the selected colour scheme.
Script Parameter: DISPLAYSYMBOLS3D.COL_REVERSE
Size
Option
The symbol size can be Fixed or Proportional.
Script Parameter: DISPLAYSYMBOLS3D.VAR_SIZE (0:Fixed Size, 1:Proportional Size, default "0")
Size ()
The Fixed symbol size in View units. The Calculate button resets the field to the default estimated value.
See Application Notes below for more information.
Script Parameter: DISPLAYSYMBOLS3D.SIZE
Channel
Select a channel from the drop-down list to be used for sizing the symbols. Enabled if the Proportional size option has been chosen. The list contains all numeric channels from the active database. Disabled if the dialog is opened in edit mode.
Script Parameter: DISPLAYSYMBOLS3D.SIZE_CHANNEL
Minimum ()
The minimum symbol size in View units. The Calculate button resets the field value to the default estimated value.
Script Parameter: DISPLAYSYMBOLS3D.MIN_SIZE
Maximum ()
The maximum symbol size in View units. The Calculate button resets the field value to the default estimated value.
Script Parameter: DISPLAYSYMBOLS3D.MAX_SIZE
Use log scale
Select this option if log distribution is desired for plotting proportionally sized symbols. Auto-selected if the Channel is of “Assay class”.
Script Parameter: DISPLAYSYMBOLS3D. LOG_SCALE
The current database must have defined X and Y channels in order to display 3D symbols.
A 3D Symbols group will take on the name of the database, without any prefixes or suffixes appended; the group name can be modified afterwards in the 3D Manager.
Plotting 3D Symbols into an empty 3D view will assign the coordinate system and units from the current database to the 3D View. Adding Symbols to a 3D View that has a different defined coordinate system (or units) from the current database will first reproject the locations of the symbols into the coordinate system (or units) of the 3D view.
3D Symbols groups created in versions newer than 9.0 will not re-scale if Axes Scaling is modified (3D View Settings dialog).
Default Symbol Size Estimates
The default size estimation takes into account the XYZ extents of the source database as well as the number of data points. The following formulae (with results rounded to 1 significant digit) are being used in determining a fixed size estimate, as well as minimum and maximum estimations for the proportional size option:
divFactor = Max(20, sqrt(nDataPoints);
Size = lengthOfDiagonalXYZ / divFactor
Minimum = 0.5 * Size
Maximum = 1.5 * Size
Setting Colours using Scripts
For batch processing using the Fixed colour option (VAR_COL="0"), choose COLOUR values from the list below:
| Value |
Colour |
| K |
black |
| N |
none |
| R |
red |
| G |
green |
| B |
blue |
| C |
cyan |
| M |
magenta |
| Y |
yellow |
| K127 |
grey |
| K63 |
lightgrey |
| R127 |
lightred |
| G127 |
lightgreen |
| B127 |
lightblue |
| C127 |
lightcyan |
| M127 |
lightmagenta |
| Y127 |
lightyellow |
| K0 |
white |
