Create Plan Maps and Data Integration in Drillhole
Sample data can be found in your "...\Users\Public\Documents\Geosoft\Desktop Applications \data\target" folder.
Plan maps provide surface views of drillhole collars, coordinates, positioning grids, drillhole traces and other information, such as the title block and a list of the holes. In the Drillhole system, plan maps represent an important organizational and navigational tool that enables you to quickly display drillhole collars and evaluate drilling progress.
You can replot your Plan map using the
To Create a Plan Map:
On the DH-Plot menu, click Plan Map.
The Plan Map Parameters dialog will appear. -
Fill in the information across the various tabs of this dialog.
- For more information on the Plan Map Parameters dialogs, click the Help button on the individual tabs.
Click OK to generate your plan map.
By default the collar locations are plotted using a circle symbol. There are several parameters available to help you customize the display of your plan map. The following table describes each tab in the Plan Map Parameters dialog box.
