Coordinate System - Copy From
Use the Copy Coordinate System From dialog to retrieve and display a coordinate system from another location.
Copy Coordinate System From dialog options
File type |
Use the drop-down list to select the file type from which to copy the coordinate system: |
File name |
Use the drop-down list or the browse[...] button to locate the file name from which to retrieve the coordinate system. |
Channel |
The Channel parameter is enabled when the "Database" file type is selected. Use the drop-down list to select the channel from which to retrieve the coordinate system. |
If the output coordinate system is predetermined, the input coordinate system may be modified. For instance, if a geographic coordinate system is required and a projected coordinate system is input using the Copy From button, only the datum and local datum transform portions of the input coordinate system are retained; the projection method is dropped, and the units are changed to degrees.
