Coordinate System - Custom Local Datum Transform
Use the Custom Local Datum Transform dialog to define a custom local datum transform (LDT) for the selected projection. This is useful when your measurements (dX, dY, dZ, scale, or rotation) are slightly different from the provided standard ones.
Custom Local Datum Transform dialog options
Datum |
Non-editable field that displays the datum name of the current coordinate system. |
Area of use |
Enter the description for the new local datum transform. |
Translation |
Specify the translation parameters in X, Y, and Z. |
Rotation |
Specify the rotational angles in X,Y, and Z. |
Scale adjustment |
Enter the scale adjustment (in ppm). This adjustment is defined in terms of the difference from unity. That is, a value of 10 ppm (+0.00001) will translate to a scaling factor of 1.00001, and a value of -10 ppm means the actual scale is 0.99999. |
Once the parameters and the area of use description are defined, the custom local datum transform will be added to the file ldatum.csv and to any other files that need to be aware of it (i.e., datum.csv, and/or ipj_pcs.csv, and/or datumtrf.csv, and/or area_of_use.csv) and saved in the user folder %USERPROFILE%\Documents\Geosoft\Desktop Applications\csv.
Learn more about Local Datum Transforms.
