Merge Databases
Use the DBMERGE GX to merge the contents of one or more databases into another. The option is available with the following menus:
Database > Import > Geosoft Database Merge
Database Tools > Database Utilities > Merge Databases
Merge Databases dialog options
Database to modify |
Specify the name of the target database. The current database is selected by default. Script Parameter: DBMERGE.GDB1 |
Database(s) to merge |
Select one or more databases to merge into the database to modify. Script Parameter: DBMERGE.GDB2 (separate multiple items with the ‘|’ character.) |
Lines/groups to merge |
Choose from one of the two available options:
Missing lines in the database to modify will be created during the merge process. Script Parameter: DBMERGE.LINES |
Channels to merge |
Missing channels in the database to modify will be created during the merge process. Script Parameter: DBMERGE.CHANNELS |
Replace existing data? |
Decide how data is merged into the database to modify:
Script Parameter: DBMERGE.REPLACE |
