Export to Shape File(s)
Use the Database > Export > Shape File(s) menu option (EXPSHP GX) to export a GDB database to a shapefile (or files).
Export to Shape File(s) dialog options
Output shapefile name/base name
File name, .SHP assumed if not provided.
Script Parameter: EXPSHP.FILE
Channels to save
"D" for displayed channels. "A" for all channels.
Script Parameter: EXPSHP.CHAN
Lines/Groups to save
"D" for the displayed line only. "S" for all selected lines. "A" for all lines.
Script Parameter: EXPSHP.LINE
Save lines to
Lines will be saved to a single file if EXPDB.SINGLE is set to "S" for single shapefile output and to individual shapefiles if it is set to "M" (for multiple shapefiles output).
Script Parameter: EXPSHP.SINGLE: S: Single, M: Multiple tables
Either displayed data channels or all data channels may be exported. Additionally, you can export the displayed line, selected lines, or all lines. If the output files already exist, they will be overwritten.
The system offers you several choices for creating a shapefile: You can either export worksheets (i.e. lines or groups) in an Oasis montaj database to individual files or to a single file. The following describes the options available for each.
Individual Tables (export as lines, groups, or lines and groups)
Lines
Each line has its own shapefile in the output. As a rule of thumb, if you are working with multiple lines, we recommend that you export lines as individual shapefiles so that you can keep track of them in future. If you are working with a single line (i.e. geochemical data), it is more likely that you will export the line as a single table. The line names will be used as suffixes for the shapefiles created with the base file name followed by an underscore as a prefix.
Groups
Groups (such as individual drillholes in a Target database) will be saved to individual shapefiles.
Lines and Groups
If both lines and groups appear in the same Oasis montaj database, then only the type which is currently displayed will be exported. For instance, if a group is displayed, then only groups will be exported. If a line is displayed, only lines will be exported. If your database contains both lines and groups and you wish to save them all to shapefiles, you may do so by running the command twice, once when displaying a group, and a second time while displaying a line.
Single Table
All lines are stored in a single shapefile. The file will contain an attribute field named Line that contains the line names of the entries in the database.
