Display 2D Spectrum
Use the 2D Filtering > Display 2D Spectrum option (FFT2PSPC GX) to calculate the power spectrum of an FFT2 Transform image.
Display 2D Spectrum dialog options
Input transform grid |
Select the name of the input transform file. Script Parameter: FFT2PSPC.TRN |
Output 2D spectrum grid |
Specify the name of the output power spectrum file. Script Parameter: FFT2PSPC.SPC |
![Closed](../../../Skins/Default/Stylesheets/Images/transparent.gif)
NY= original Y dimension
DX= X element separation
DY= Y element separation
WX= 1/(NX*DX), wavenumber increment in X
WY= 1/(NY*DY), wavenumber increment in Y
QX= 1/(2*DX) , Nyquist in X
QY= 1/(2*DY) , Nyquist in Y
0 +WX +QX
r i r i r i
v NY-1 . . . . . . . . . . -WY
e . . . . . . . . . . -WY*2
c . . . . . . . . . .
t . . . . . . . . . .
o . . . . . . . . . .
r . . . . . . . . . .
. . . . . . . . . . -(QY-WY)
^ . . . . . . . . . . QY
| . . . . . . . . . . QY-WY
2 . . . . . . . . . . WY*2
1 . . . . . . . . . . WY
0 . . . . . . . . . . 0
0 1 2 (NX+1) -> element
(The X(-)Y(+) portion will be complex conjugate of the X(+)Y(-) portion)
(The X(-)Y(-) portion will be complex conjugate of the X(+)Y(+) portion)
The power spectrum storage in file .SPC will be:
(The power spectrum is (r*r+i*i))
0 +WX +QX
NY-1 . . . . . QY
. . . . . QY-WY
. . . . . WY*2
. . . . . WY
. . . . . 0
. . . . . -WY
. . . . . -WY*2
2 . . . . .
1 . . . . .
0 . . . . . -(QY-WY)
0 NX/2
(The X(-)Y(+) portion will be the same as the X(+)Y(-) portion)
(The X(-)Y(-) portion will be the same as the X(+)Y(+) portion)
