Vertical Integration (INTG)
Use the Vertical Integration option (FFT2CON_INTG GX) to apply the vertical integration filter.
Vertical Integration dialog options
There are no dialog options for this filter. Press OK on the dialog to apply the filter.
Calculates the vertical integral of the input transform. This is the inverse of the vertical derivative. The zero wavenumber is set to 0.
Vertical integration
![Closed](../../../Skins/Default/Stylesheets/Images/transparent.gif)
k |
u |
v |
r |
θ |
