Low-pass (LPAS)
Use the Low-pass option to apply the low-pass filter.
Low-pass Filter dialog options
Cutoff wavelength |
The cutoff wavelength in ground units k0-1. All wavelengths shorter than this value are removed. |
The low-pass filter can be used to pass or reject a range of wavelengths contained in the data. However, applying such a simple cutoff filter operator to an energy spectrum almost invariably introduces a significant amount of oscillation (also known as Gibbs’ Phenomenon). This filter is present for the sake of completeness. We recommend that you use a tapered filter such as the Butterworth filter (BTWR).
Low-pass
L(k) = 1 | for k ≤ k0 |
L(k) = 0 | for k > k0 |
Wavenumber domain variable definition
k |
u |
v |
r |
θ |
