Display Grid on Map
Use the Grid and Image > Display on Map > Grid menu option (geogxnet.dll(Geosoft.GX.GridUtils.DisplayGrid;Run)*) to place a grid image on a map.
You can display up to four grids or images on a map at once by using one of the composite grid options available.
Main toolbar:
- Grid and Image > Display on Map > 2-Grid Composite
- Grid and Image > Display on Map > 3-Grid Composite
- Grid and Image > Display on Map> 4-Grid Composite
3D Viewer:
- Add to 3D > 2D Map Tools > Grid and Image Display > 2-Grid Composite
- Add to 3D > 2D Map Tools > Grid and Image Display > 3-Grid Composite
- Add to 3D > 2D Map Tools > Grid and Image Display > 4-Grid Composite
Display Grid dialog options
Grid name |
Select the grid file to display on a map. For a list of supported grid formats, see the topic Supported Data Formats. For details on crooked sections, see the topic Crooked Section Grids. Script Parameter: GRIDIMG1.GRID |
Colours |
Select the colour scheme for rendering the image of the selected grid. If you mouse over the Colours entry, a tool tip will display the name of the colour table file. To modify the selection, click on the colour entry and then navigate through the scheme categories. Script Parameter: GRIDIMG1.COLOR |
Colour method |
Specify the colour zoning method for rendering colour distributions. Select one of the options below:
If the selected colour scheme is an .itr file or a .zon file, the colours are already attributed to data ranges, and this entry is not available. Script Parameter: GRIDIMG1.ZONE [0 – Default (set in the global setting); 1 –Linear; 2 – Normal distribution; 3 – Histogram equalization; 5 – Log-Linear; 6 – As last displayed] |
Brightness
The normal brightness is defined at 0. You can change the brightness from -100 (black) to 100 (white) using either the slider bar or by entering an exact value. Script Parameter: GRIDIMG1.BRIGHTNESS [range: 0 to 100] |
Reverse colour distribution
The colour table can be used in reverse order. Check this box to reverse the order of the colour scheme. Script Parameter: GRIDIMG1.REVERSE [0-No | 1 - Yes] |
Smoothing
For display purposes, by default, the grid is first interpolated to a smooth image at the screen resolution. If you prefer to honour the grid resolution, leave the Smoothing option unchecked: the image will appear pixelated, and the colour will change at the actual grid interval rather than the screen resolution. Script Parameter: GRIDIMG1.PIXEL [0-No | 1 - Yes] |
Shading
Adding a shading effect to the colour grid emphasizes the subtle changes in the data that would otherwise be subdued. Presenting the data shaded is optional. See the Shading section in the Application Notes for further details. Script Parameter: GRIDIMG1.SHADOW [0-No | 1 - Yes] |
Add colour bar
Check to add a colour bar for this grid on the map. Script Parameter: GRIDIMG1.COLOUR_BAR [0-No | 1 - Yes] |
Location |
Specify the location as Default registration (default option) or Fit to an area (user defined - interactive only). When you place an image or grid on a map, the system assumes you are using the default registration system as defined in the grid or image header. If you want to position the grid interactively, select the option Fit to area; then use the mouse to define a rectangular area on the map and the system will fit the grid (or image) exactly to this area. Script Parameter: GRIDIMG1.REG ( 0 for default registration from image) |
[More] |
Data Range |
Contour interval |
The minimum contour interval for rounding the colour breaks. Provide a suitable number around 1/10 of the standard deviation of the data to generate a similarly coloured image but with rounded colour break values. Script Parameter: GRIDIMG1.CONTOUR |
Minimum value |
All grid values below this threshold will be displayed with the lowest colour defined in the table. To reset it to default, click on the calculator button. Script Parameter: GRIDIMG1.MINIMUM |
Maximum value |
All grid values above this threshold will be displayed with the highest colour defined in the table. To reset it to the default, click on the calculator button. Script Parameter: GRIDIMG1.MAXIMUM |
Shading Effect |
Enabled when the Shading option is checked. |
Wet look |
The shading effect consists of superimposing on the colour image the grey-scale gradient of an overlapping data grid. This is known as the normal shading effect. Script Parameter: GRIDIMG1.SHADING_TYPE [0 – Normal, 1 – Wet Look] |
Shadow grid name |
Select a coinciding grid, such as a topography grid, to generate the shading. If left blank (default), the input grid will be used to generate the shading. Script Parameter: GRIDIMG1.SHADOW_GRID |
Inclination |
Illumination inclination. By default inclination is set to 45°. Script Parameters: GRIDIMG1.INCLINATION |
Declination |
Illumination declination. By default declination is set to 45°. Script Parameters: GRIDIMG1.DECLINATION |
Vertical scale factor |
The scale factor to apply in order to balance the shading. The scale determines how the shading tool interprets the values in your grid. For example, if you use a large scale, you will exaggerate the vertical appearance of your grid and see deep valleys. If you use a very low scale, you will flatten the grid and see very smooth hills. See the Shading section in the Application Notes for further details. The default vertical scale factor is set to 2.5 over the mean of the gradient of the input grid. Where: n=i*j i,j -> grid indices dG/dx & dG/dy -> gradient in X & Y directions To obtain this value or to reset it, click on the calculator button. Script Parameters: GRIDIMG1.VERTICAL_SCALE |
[New Map] [Current Map] |
Click the New Map button to display a grid on a new map. If the map already exists, you will be prompted to overwrite or provide a different name. Click the Current Map button to display the grid on the current map. Script Parameters: GRIDIMG1. NEW [1 - New map, 0- Current map] |
Accessing ER Mapper Bands
Oasis montaj enables you to work with a variety of grid and image formats — freely importing them, specifying certain grid parameters (such as specific bands) and exporting them as required. The procedure for accessing (importing) an image by placing it on a map is similar to the method for importing a grid.
The basic mechanism for accessing grids and images is provided through a special technology called DAT. DATs are DLLs that provide interfaces to a variety of image and grid formats. Each DAT has a 3-letter identifier and a number of parameters that can be used to "decorate" the file name when accessing a file for import or export.
For example, to access the third band of a TM image in an ER Mapper image named "CITY.ERS", you would "decorate" the name as follows:
City.ers(ERM;band=3)
The first parameter in the decoration block (inside the parentheses) is always the 3-letter DAT identifier, which you must supply any time you want to specify a decoration. If you do not specify a decoration, the default DAT type is taken from the "DAT Settings" parameter in the Advanced Settings dialog.
You can also specify decorations when exporting grids and images or use decorations to convert them to another format.
For a complete list of decorations currently available for use in the system see the topic XGD DAT Qualifiers.
Colour Tables
To help you navigate through the colour schemes more effectively, the installed colour scheme files (e.g., colour tables (*.tbl)
, colour zones (*.zon)
, etc.) are organized in subfolders, each defining a category.
In addition, this tool keeps track of three custom categories, and you are also able to browse outside of the structured categories.
The colour schemes have been subdivided into the following categories:
System Categories
Geophysics: Contains colour tables appropriate for displaying single-entity geophysical data, such as total magnetic intensity, gravity, resistivity, induced polarization.
Topography: Contains colour tables that convey the feel of terrain and should be used to display elevation or topography.
Monochromatic: Radiometric data is generally displayed as an overlay of three normalized elements on a single colour map; each element is displayed using gradations on a single colour. All monochromatic tables along with shadow tables are found under this category.
Heat map: Originally devised for depicting financial information and later to display the frequency of web page visits, the schemes found under this category lend themselves well to thematic data display.
CET perceptual: The Centre for Exploration Targeting of the School of Earth Sciences at The University of Western Australia has produced a set of perceptual colour schemes that are freely available. For your convenience, we provide them with Oasis montaj.
Perceptually uniform: The perceptual contrast of adjacent colours may vary widely for some colour schemes. The result is that in some sections of the colour scheme, the data variation will be less visually noticeable (dead zone) than in other sections, preventing a proper interpretation. Perceptually uniform colour schemes offer the same visual contrast throughout the colour scheme.
Miscellaneous: Some specialized Oasis montaj extensions trigger the installation of additional colour schemes. In order to easily find them, these schemes are grouped in a separate category labeled "Miscellaneous". This category will only appear if you actually have such extensions.
Contextual Categories
Favourites: The default colour scheme defined in the General Settings dialog (accessed from the menu Project > Settings > General), along with any other schemes that you have tagged as favourite, are made available under this category.
To change the default colour scheme, go to the General Settings dialog.The category points to the "%USERPROFILE%\Documents\Geosoft\Desktop Applications\tbl\Favourites" folder. Tagging/untagging a favourite scheme will add/remove the corresponding colour scheme file to/from this folder.
My Colour Schemes: You may want to access your custom colour schemes that you have compiled over time. These can be a collection of tables you downloaded from various sources or generated yourself. The category points to the "%USERPROFILE%\Documents\Geosoft\Desktop Applications\tbl" folder, which persists across upgrades.
This category will only appear if you have colour scheme files in the folder noted above.Project directory: You may have custom colour schemes specific to your project that you access from your working directory.
This category will only appear if you have colour scheme files in your working folder.
[Browse...]
Opens the file selector dialog Browse for Colour Scheme File and defaults to the location of the currently selected colour scheme file.
Provides the option to navigate outside the above structure and locate a colour scheme file. Use the buttons listed below to toggle between the following locations:
Project Directory: your working folder
Standard Colour Schemes: the \tbl folder in your Oasis montaj program directory
My Colour Schemes: the \tbl folder in your default user profile directory (i.e., %USERPROFILE%\Documents\Geosoft\Desktop Applications\tbl)
Shading
Colour shaded grids are a valuable interpretation tool to verify gridded data quality as well as to identify structural trends within gridded data.
To display a shaded relief, Oasis montaj creates an auxiliary grid file in the directory where the input grid resides. This grid has the same base name as the input grid followed by the suffix "_s", and it gets created every time you opt to view a shaded grid. If this auxiliary grid file already exists, it is overwritten. After the shadow grid image is created, you can use the Colour Tool to modify the shading parameters interactively.
The stronger the data variation, the shorter the shadows and the faster the progression from dark to light. In addition, the higher the illumination inclination from the horizon, the shorter the progression from dark to light. In order to balance the shading to accommodate a wide range of data distributions and illumination angles, the shadow distribution is widened for strong data variations and high illumination angles through the use of the Vertical scale factor.
The shadow grid is thus calculated using the following equation:
Where:
sg -> shadow gridi,j -> ith row & jth column grid indicesinc -> illumination inclinationdec -> illumination declinationf -> 1/ VerticalScaleFactor
dG(i,j)/dx -> gradient of the i,j grid point in the X directionsdG(i,j)/dy -> gradient of the i,j grid point in the Y directionsHSV
![]() | The Hue component describes the colour itself in the form of an angle between [0°,360°]. The illustration shows the angular values of the entire colour pallet. For example, red is assigned 0° and cyan is at 180°. To abide to the Geosoft colour table format, colour must be represented with a 1 byte integer, thus the 360 range is scaled to a 255 range. When invoked, the Display Grid tool converts it to the right range on the fly. The Saturation component is between 0 & 1, where 0 indicates the absence of colour and 1 its full intensity. In the illustration, it is represented by the radius of the circle. |
The Value component spans from 0 to 1, where 0 is the darkest (black - at this point the values of H and S are irrelevant), 1 the brightest. In the illustration, it is represented by the vertical component. The S & V components influence the shading and the contrast, which are controlled by the inclination and declination of the sun angle. To abide to the Geosoft colour table format, both the S & V components are also scaled to [0,255], and the Display Grid tool converts them to the right range on the fly. The colour distribution for a HSV image (1st column of hsvc.tbl) is translated to the 3 RGB components on the fly and scaled for brightness and contrast ( 2nd & 3rd columns of hsvg.tbl) along the sun shadow angle. Unlike the RGB colour distribution option, the HSV tables are not static tables but generated on the fly, and as a result you can not use the Colour tool to modify it. | |
