Import USGS POST File
Use the Database > Import > USGS > POST File menu option (IMPOST GX) to import USGS POST files.
Import POST File dialog options
Import file (POS) |
Input POST data file name. Script Parameter: IMPOST.DATA |
A post file is a binary file in which each record contains a record identification ID (8 ASCII characters), X (real*4) and Y (real*4) coordinates, and any number of dependent variables Z1,Z2,… (read*4 for each one).
If the Specify coordinate system on import setting is set to "Yes" in the General Settings, and no coordinate system is defined for the current X and Y channels, Set Coordinate System will be called to set the projection on the X and Y.
