Scan Picodas Data
Use the Database > Import > Picodas PDAS > Scan Data menu option (SCANPICO GX) to scan a given Picodas file and create a default import template. This template can then be edited to remove unwanted channels and rename lines as needed using the ALIAS keyword.
Scan Picodas Data dialog options
Picodas Data file to scan |
Picodas data file name. Script Parameter: SCANPICO.DATA |
Create Picodas Template file |
Template file name (.I1 assumed). Script Parameter: SCANPICO.TEMPLATE |
