Voxels to Vector Voxel
Use the Voxels to Vector Voxel option (geogxnet.dll(Geosoft.GX.VoxUtils.ConvertVoxelsToVectorVoxel;Run)*) from the Voxel > Conversions menu, to assemble 3 voxel files into a Vector Voxel model.
Voxels to Vector Voxel dialog options
A vector voxel is a voxel model represented by 3 scalar values at each voxel point. These values define the 3 scalar components of a vector. A vector voxel model is displayed in the 3D viewer with directional arrows; the size and colour of which are indicative of the magnitude.
A vector voxel can be assembled from its 3 components in the standard Cartesian coordinate system, or a rotated coordinate system. In the standard Cartesian coordinate system, the scalar components are denoted as the X, Y, & Z component voxels. The X component is analogous to Easting, the Y component analogous to Northing and the Z component direction is upwards positive. In the rotated coordinate system, the projected components are denoted as U, V, & W. The U component is positive in the direction of the specified inclination and declination, the V and W components are perpendicular to each other and to U.
Figure 1: 3D Vector displayed with respect to Cartesian coordinates; Z is upwards positive.
Figure 2: 3D vector displayed with respect to rotated coordinates; U is positive in the direction of the specified inclination and declination.
If a 3D Viewer is open when running the conversion, the output vector voxel will be displayed in the 3D Viewer window. Otherwise, the output voxel will be displayed into a new Voxel Viewer window. If the output voxel does not display, open the 'Advanced Settings' dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the 'Display Created Voxels' option is set to "True".
Cartesian
Rotated
Inclination (degrees)
