Bar Symbol Plot Legend
Use the Geochem Map > Point Plots > Bar Plot Legend menu option (CHBARLEG GX) to plot a legend for the Bar symbol plots.
Bar Symbol Plot Legend dialog options
If this GX is run from the CHBAR GX, or immediately following it, the following parameters will already be set.
Specify Channels
Channel X |
Select a channel from the drop-down list. All values must be specified. Script Parameter: CHROSE.CHANX (Where X is a value from 1 to 8) |
Next> |
Proceed to define scaling. |
<Back |
Return to the main dialog |
Finish |
Plot the legend. If channels or colours remain to be defined, the appropriate dialog will appear before you can plot. |
Specify Scaling
Specify Fill Colours
(Channel Name) colour |
Select a colour from the drop-down list. All values must be specified. Script Parameter: CHROSE.COLX (Where X is a value from 1 to 8) |
<Back |
Finish |
This GX is designed to be run from the CHBAR GX, but it may be run on its own.
