Database Channels to Array
Use the Database Tools > Array Channels > Database Channels to Array menu option (geogxnet.dll(Geosoft.GX.Database.ChannelsToArray;Run)*) to select and display standard database channels as an Array channel.
Database Channels To Array dialog options
New array channel |
Specify the name of the New array channel in the text box provided. |
Database channels |
The channels in your current open database are displayed in the Database channels list. |
Array channel elements |
The array channel elements for your new array channel are displayed in the Array channel elements list. |
[Add] |
Select (highlight) the database channels to be added to an array channel. Click the Add -> button to move the selected channels to the Array channel elements list. |
[Remove] |
Select (highlight) the array channel elements to be removed from an array channel. Click the <- Remove button to move the selected array channel elements to the Database channels list. |
