Heading Calculation
Use the Heading Calculation menu option (geogxnet.dll(Geosoft.GX.Database.HeadingCalculation;Run))* from Database Tools > Database Utilities to calculate the heading direction of the survey lines.
Heading Calculation dialog options
Output heading channel |
Specify the name of the channel in which to save the calculated heading values. By default, the output channel name is set to "Heading"; however, you can override the default. Script Parameters: HEADING_CALCULATION.OUTPUT_HEADING_CHANNEL |
Number of smoothing passes |
Select the number of smoothing passes. The default is 1 (see Application Notes for more details). Script Parameters: HEADING_CALCULATION.SMOOTHING_PASSES |
The Heading Calculation GX operates on the current GDB; if no database is open, a prompt to select a database is displayed. Headings are relative to north in the clockwise direction. The designated X & Y channels are used to calculate the headings: if no designated X & Y channels are found in the database, an error message informs you to assign the X ,Y channels and try again.
The heading is calculated as:
It is recommended to apply smoothing, as the point to point heading may be varying more than desired depending on the survey conditions. The smoothing filter applied is a simple convolution filter with the coefficients: 0.05,0.1,0.2,0.3,0.2,0.1,0.05.
