Horizontal Gradient
Use the Grid and Image > Filters > Horizontal Gradient menu option (geogxnet.dll(Geosoft.GX.GridUtils.GridGrad;Run)*) to calculate the grid gradient amplitude, or in a specified direction.
Horizontal Gradient dialog options
Input grid name |
The name of the input grid. Script Parameter: GRIDGRAD.GRD |
Output grid |
The name of the grid in which to place the result. Script Parameter: GRIDGRAD.GRAD |
By default, the directional gradient will be calculated. If this option is selected then you have to provide the azimuth angle θ of the horizontal derivative. The equation applied is:
Alternatively, the magnitude of the horizontal gradient can be calculated as:
Script Parameter: GRIDGRAD.METHOD Script parameter settings:
Gradient direction |
The angle at which to calculate the gradient (in degrees). Counter clockwise from positive X (CCW from +X) is defined as: Script Parameter: GRIDGRAD.ANGLE |
A 3x3 point convolution filter is applied to the grid to produce the gradient result.
Gradient magnitude
Directional gradient
