Boolean Operations
Use the Grid and Image > Merge Grids > Boolean Operations menu option (GRIDBOOL GX) to mask one grid against another to produce a new output grid.
Boolean Operations dialog options
File name of the first grid. Script Parameter: GRIDBOOL.GRD1 |
Input grid file 2 |
File name of the second grid. Script Parameter: GRIDBOOL.GRD2 |
Output grid |
File name for the output grid. Script Parameter: GRIDBOOL.OUT |
Boolean logic option |
Boolean logic option for masking (default = AND). Script Parameter: GRIDBOOL.BOOL |
Size of output grid |
Option controlling size of output grid area (default = minimum) Script Parameter: GRIDBOOL.SIZ |
Grid values used in overlap areas |
Option controlling values to use in overlapping areas (default = Grid 1 only). Script Parameter: GRIDBOOL.OLAP |
Applies Boolean functions between two input grids to produce a combined output grid. The Boolean operations are based on the presence or absence of a dummy value at a grid point.
Examples of Applications:
- It can be sued to replace dummy values in a filled grid in order to match the valid area of an original grid (i.e., as used by MAGMAP in the final stage of processing to remove filled areas from a processed grid).
- It can also be used to show the overlapping parts of two grids.
- With the averaging function, it can be used to merge two overlapping grids into a single grid.
Handling Different Projections, Cell Sizes, Origins, and Offsets
As of v6.0, the two grids need not share the same projections, origins or cell sizes. If differences in these parameters are found, then the second grid will be re-projected and interpolated to match the values of the first grid. In such cases the output grid will always have origin coordinates which are integral multiples of the cell size, in both X and Y. (In such cases, if the origin coordinates of the first grid are not integral multiples of the cell sizes, it too is interpolated to the output locations before the BOOL operation. HOWEVER, if the two grids share the same projections and cells sizes, and both have the same "shift" of cell boundaries in X and Y, then the output grid will share the shift, and no re-interpolation or inheritance of the grids prior to booling will be performed.)
