Create PLY File from Map Group
Use the Map Tools > CAD Tools > Create PLY File from Map Group menu option (GROUPPLY GX) to create a polygon file from all polygons contained in a map group.
Create PLY File from Map Group dialog options
Select the View/Group from which to extract polygons. All closed polygons in the group will be extracted and placed in the polygon file. The polygon coordinates will be in the projection of the view. Script Parameter: GROUPPLY.GROUP |
Output polygon file |
The name of a polygon file in which to place the polygons. If the polygon file exists, you will be asked if you want to Replace or Append to the file. Script Parameters: |
A polygon file lists the vertices of each polygon in a simple ASCII column format.
Example:
1374672.4138 6174672.4138
1385327.5862 6174672.4138
1385327.5862 6185327.5862
1374672.4138 6185327.5862
poly 2
1382953.8023 6182380.6322
1383749.0087 6182966.7435
1384494.8575 6182488.6008
1384154.8386 6181835.6524
1383880.6287 6182385.7738
1383200.5908 6181804.8041
1382624.7515 6182103.0007
poly 3
1382937.3491 6181506.6069
1383589.967 6181624.8573
1383880.6287 6182190.4035
1384110.9648 6181357.5091
1384681.3197 6181917.9135
1384555.1839 6180946.2025
1383798.3657 6180889.6483
1382898.9606 6181054.1704
