GDB to Voxel
Use the Voxel > Conversions > GDB to Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ImportGDBToVox;Run)*), to import a channel from the current Geosoft database to a Geosoft voxel.
GDB to Voxel dialog options
Data channel |
Select the database channel holding the data values to be imported to a voxel. Script Parameter: IMPORTGDBTOVOX.DATA_CHANNEL |
Output voxel |
Specify the name of the Geosoft Voxel file to generate (.geosoft_voxel). Script Parameter: IMPORTGDBTOVOX.OUTPUT_FILE |
If a 3D Viewer is open during the import, then the output voxel will be displayed in the 3D Viewer window. Otherwise, the output voxel will be displayed into a new Voxel Viewer window. If the output voxel does not display, open the Advanced Settings dialog (Project > Settings > Advanced) and under the Voxel Settings section, check if the Display Created Voxels option is set to "True".
The import does not do gridding. The data must already be in a rectangular grid form. The import does support non-uniform cell sizes as long as all the cell sizes can be determined. The voxel created will have the same projection as the X, Y, Z channels and be of the same data type as the Data channel.
Non-Uniform cell sizes are handled on per axis (X, Y, Z).
The example fragment below defines a non-uniform voxel with the X axis having four different cell sizes:
0 100 4 33.0
15 100 4 34.5
22 100 4 36.3
26 100 4 37.02
30 100 4 5.2
40 100 4 523
The resulting X axis would be defined as:
Min Point Max Cell
-10 0 10 20
10 15 20 10
20 22 24 4
24 26 28 4
28 30 32 4
32 40 48 8
Note that if the points do not produce a finite non-uniform cell array for any axis, the import will fail.
Use the gridding tool to produce voxels from random data points.
