Import Datamine DM File(s)
Use the Map > Import > Datamine DM File(s) menu option (IMPDATAMINE GX)  to import a Datamine (*.dm) file into an Oasis montaj map.
Use the Add to 3D > Imports > Datamine DM File(s) menu option (IMPDATAMINE GX)  to add a Datamine (*.dm) file to a 3D View.
Datamine File Import dialog options (3D View)
Datamine file(s)
Select one or more Datamine (*.dm) files to import.
Script Parameter: IMPDATAMINE.FILES (Separate files with the "|" character.
Import Datamine DM File(s) dialog options (Map)
Datamine file(s)
Current Map
Click this button to import the file(s) to the current map.
Script Parameter: IMPDATAMINE.MAPOUT (Option: 0 : Current Map)
New Map
Click this button to import the file(s) on a new map.
Script Parameter: IMPDATAMINE.MAPOUT (Option: 1 : New Map)
Import to a New Map dialog options
Project data as
If the default option, "Plan" is selected, the data will be presented as a simple plan map. Select "E-W Section" to present and project the data as an East-West vertical section. Select "N-S Section" to present and project the data as a North-South vertical section
Script Parameter: IMPDATAMINE.ORIENT (0 : Plan, 1 : E-W, 2 : N-S)
  • When the data is projected to a 2D view (plan or section) some 3D information can be lost. See the Application Notes below for more information.
  • Map scale
    The map scale is optional for 2D views. If not specified, a new map is created with a default size of 30 cm by 30 cm, and the scale is automatically determined to fit the data
    Script Parameter: IMPDATAMINE.MAPSCALE (default = not defined)
    Create a New Map dialog options
    Map name
    Specify the name of the new map. Automatically pre-populated with the same name as the input Datamine DM  file name.
    If the Datamine DM file(s) are imported to a current map, the imported data will be projected onto the plane of the current data view. If the view is a normal "plan" view, then the Z-dimension information will be lost. If the view is a "section" view (such as those created for drillhole sections in Target), the data is projected horizontally onto that plane. If imported to a 3D View, the objects are plotted as in the original files.
    The following Datamine file types are currently supported:
    • Points
    • Strings (lines)
    • Wireframes
    Often, Datamine files can be opened and interpreted as two or more different types of files. For instance, as a Wireframe point file and as a string file. In these cases, a dialog is displayed for the user to select which of the types to select. Do not select the wireframe point option unless you have the accompanying wireframe triangle file.
