Import Vulcan Triangulation File(s)
Use the Imports > Vulcan Triangulation File(s) option (geogxnet.dll(Geosoft.GX.ImportVulcanTriangulation;Run)*) from the 3D Viewer Add to 3D menu to import a Vulcan Triangulation file into a Geosoft surface (geosurface) file.
A new geosurface file can be created, or the Vulcan Triangulation surface can be appended to an existing geosurface file. The geosurface file is added to the current project (Project Explorer > Geosurfaces) and to the current 3D View.
Import Vulcan Triangulation File(s) dialog options
Triangulation file(s)
Select one or more Vulcan Triangulation files to import.
Script Parameter: IMPORTVULCANOOT.INPUT_OOT (Separate files with the "|" character).
Geosurface file
Specify the name of the geosurface file (*.geosoft_surface). Automatically pre-populated with the same file name as the input file.
Script Parameter: IMPORTVULCANOOT.OUTPUT_SURFACE
Import file
The output will be saved to a new or existing geosurface file. The new or existing geosurface will be displayed in the 3D View.
Script Parameter: IMPORTVULCANOOT.USE_EXISTING_GEOSURFACE (0: Create new (default), 1: Append)
Vulcan Triangulation Coordinate System
Coordinate system
This displays the Coordinate System dialog which allows you to specify the correct coordinate system information for the incoming Triangulations file. Use the drop-downs to define a coordinate system for the Triangulations file. The coordinates of the Vulcan Triangulation file (its native coordinate system) will be re-projected to that of the 3D View, if necessary. If multiple Triangulation files are selected, the specified coordinate system will be applied to all files.
Script Parameters:
IMPORTVULCANOOT.IPJ_NAME (can be an EPSG coordinate system name)
IMPORTVULCANOOT.IPJ_DATUM
IMPORTVULCANOOT.IPJ_METHOD
IMPORTVULCANOOT.IPJ_UNITS
IMPORTVULCANOOT.IPJ_LOCALDATUM
The colours specified in the Triangulation file will be used in the display. These can be edited in the Attributes tab in the 3D View.
