Import MapInfo TAB or MIF File(s)
Use the MapInfo TAB or MIF File(s) option (IMPORTMI GX) to import a MapInfo TAB or MIF file into an Oasis montaj map or to add it to a 3D View.
A MapInfo TAB or MIF file contains both "attribute" data and geographical information. When importing TAB or MIF files, Oasis montaj stores the attribute data into the current (or a new) database and displays the geographic information on the current or a new map.
The option is available from the following locations:
Import MapInfo TAB or MIF File(s) dialog options (3D View)
MapInfo TAB or MIF file |
Select one or more MapInfo TAB or MIF file(s) to import. Script Parameter: IMPORTMI.TAB (Separate files with the "|" character). |
Import MapInfo TAB or MIF File(s) dialog options (Map)
Import data to |
Select whether to import the database information of the MapInfo TAB or MIF file to a "New database", "Current database" or "Do not import". If you selected to create a new database, the system will prompt you to specify a new database name.
Script Parameter: IMPORTMI.DBOUT (0 : Current Database, 1 : New database (default), 2 : Do Not Import) |
Plot map to |
Select whether to import the map (geographical) information of a MapInfo TAB or MIF file to a "New map", "Current map" or "Do not import". If you selected to create a new map, the system will prompt you to specify the data range to map name. Script Parameter: IMPORTMI.MAPOUT (0 : Current Map, 1 : New map, 2 : Do Not Import) |
The map scale is optional for 2D views. If not specified, a new map is created with a default size of 30 cm by 30 cm, and the scale is automatically determined to fit the data Script Parameter: IMPORTMI.MAPSCALE (default = not defined) |
Create a New Map dialog options (Map)
Map name |
Specify the name of the new map. Automatically pre-populated with the same name as the input MapInfo TAB or MIF file name. Script Parameter: IMPORTMI.MAP |
Create a New Database dialog options (Map)
Import file |
Not editable.Set to the input MapInfo TAB or MIF file name. |
Import to new database |
Specify the name of the new database. Automatically pre-populated with the same name as the input MapInfo TAB or MIF file name. Script Parameter: IMPORTMI.DB |
A MapInfo TAB or MIF file contains a list of geographic "features"; each geographic "feature" has a corresponding row of "attribute data", and each feature and attribute has its analogue in an Oasis montaj map or database object. The linkage between the feature and the data is maintained by writing the X and Y location values for each shape to the Oasis montaj database, along with the data. Use the shadow cursor, as normal, to find the correspondence between rows in the database and features on the map. MapInfo features are written to the "MapInfo" view in a map. The group name is the same as the MapInfo file name (without the ".TAB" or ".MIF" suffix).
All files will be imported into the same map. Each MapInfo file that has an associated database will be imported into separate groups of the same Geosoft database.
Oasis montaj supports all the projections in MapInfo. When you import a MapInfo TAB file into Oasis montaj, the system will use the existing MapInfo projection contained in the TAB file. The data from the TAB file is automatically imported into the database and the graphics into a map file. However, MapInfo has an "unspecified" projection setting for data that has not had any projection associated with it. It is a good idea to check the projection information whenever you import data or graphics from MapInfo. To display MapInfo data or graphics on a map, follow the instructions for displaying located data or grids and images on a map.
