Import Micromine File
Use the Map > Import > Micromine File menu option (geogxnet.dll(Geosoft.GX.Micromine.Micromine;Run)*), to import a Micromine file into an Oasis montaj map.
Use the Add to 3D > Imports > Micromine File menu option (geogxnet.dll(Geosoft.GX.Micromine.Micromine;Run)*), to add a Micromine file to a 3D View.
Import Micromine File dialog options (3D View)
File to import |
Select the Micromine file to import to the current 3D view. Script Parameter: MICROMINE.INPUTFILE |
Import Micromine File dialog options (Map)
Micromine File Types
There are 7 Micromine file types that can be imported into an Oasis Montaj map: .STR, .SEC, .STP, .DAT, .SVY, .TDB, .GRD. The first 5 file types are ASCII files and share the same internal format for describing data, whereas TDB files are Microsoft Access Database files, and GRD files are in a binary format. As for the kind of data that these 7 file types describe, STR files describe strings, SEC and STP files describe profiles, TDB files describe surfaces using triangulation, and GRD files describe grids. Please refer to Micromine documentation for the format specifications of these 7 file types.
