Import Minesight File
Use the Map > Import > Minesight File menu option (geogxnet.dll(Geosoft.GX.Minesight.Minesight;Run)*), to import a Minesight file into an Oasis montaj map.
Use the Add to 3D > Imports > Minesight File menu option (geogxnet.dll(Geosoft.GX.Minesight.Minesight;Run)*), to add a Minesight file to a 3D View.
Import Minesight File dialog options (3D View)
File to import |
Select the Minesight file to import to the current 3D view. Script Parameter: MINESIGHT.INPUTFILE |
Import Minesight File dialog options (Map)
File to import |
Select the Minesight file to import. Script Parameter: MINESIGHT.INPUTFILE |
Create new map |
Select this option to import the file on a new map. Script Parameter: MINESIGHT.NEWMAP (Option: 1 : new map) (This option will be selected if no current map is detected.) |
Use current map |
Select to import file to current open map. Script Parameter: MINESIGHT.NEWMAP (Option: 0 : current map) (This option will be selected if a current map is detected.) |
Map Details (Create new map) |
Map name |
Specify the name of the new map. Script Parameter: MINESIGHT.MAPNAME |
Optional. If not specified, the new map will be created with a map scale determined to fit the data. Script Parameter: MINESIGHT.MAPSCALE |
2D plan view |
Select to display in 2D plan view. Script Parameter: MINESIGHT.NEWMAPDETAILSMODE (0: plan view) |
2D E-W section view |
Select to display in 2D E-W section view. Script Parameter: MINESIGHT.NEWMAPDETAILSMODE (1: E-W section view) |
2D N-S section view |
Select to display in 2D N-S section view. Script Parameter: MINESIGHT.NEWMAPDETAILSMODE (2: N-S section view) |
This option can be used to import Minesight files geometry elements into an Oasis montaj map or 3D view. These geometry elements can be markers (a set of points), polylines/polygons (connected line segments), or shells (surfaces and solids). They are all contained within Minesight MSR file type.
