Altitude Deviation
Use the Altitude Deviation option (geogxnet.dll(Geosoft.GX.AirborneQC.AltitudeDeviation;Run)*) from the Airborne QC menu to carry out quality control on survey flying height.
Altitude Deviation dialog options
This GX assumes that the current database is the one containing the actual survey data. The database is called the survey database. If you wish to process a different database, you may browse to add it to the project or select one from the workspace list.
Quality Control Specifications and Indicators
This GX permits four separate specifications to be tested to determine whether the airplane flight heights are within specification or not:
1) |
At each reading location, the flight height must be less than the nominal flight height plus the maximum deviation and more than the nominal flight height minus the maximum deviation. |
2) |
The flight height must be less than the nominal height plus the allowed deviation or more than the nominal height minus the allowed deviation for a distance less than the specified distance. |
3) |
The terrain clearance must be above the minimum terrain clearance at all times. |
4) |
The flight height must be below the maximum elevation at all times. |
You must specify either the maximum deviation or the allowed deviation. The check against the absolute flying height range takes precedence over the Maximum deviation and Allowed deviation tests. To disable a test, leave the corresponding field(s) empty.
This GX creates a flag channel, Flag Height, which contains numbers from -4 to 4 inclusive to indicate the result of the quality control test(s) on flight line height.
Indicator Definition
Flag |
Description |
0 |
Flight height passes both tests. |
±1 |
Flight height fails the 1st test (maximum deviation). |
±2 |
Flight height fails the 2nd test (allowed deviation over a distance). |
±3 |
Flight height fails both tests. |
±4 |
Flight height is above maximum elevation (+) / below minimum (-) terrain separation. |
Positive values in the flag channel indicate that the actual flight height is higher than the nominal height, and negative values indicate that the actual flight height is less than the nominal height.
Distance Calculation
When the Allowed deviation over distance specification is tested, the cumulative distance along the actual survey path is used instead of the distance along the ideal line path.
