Flight Path Deviation
Use the Flight Path Deviation option (geogxnet.dll(Geosoft.GX.AirborneQC.FlightPathDeviation;Run)*) from the Airborne QC menu to carry out quality control on airplane flight path.
Flight Path Deviation dialog options
This GX assumes that the current database is the one containing the actual survey data. The database is called the survey database. If you wish to process a different database, you may browse to add it to the project or select one from the workspace list.
The "Ideal Line Path Database''
This is the database created when a proposal is made during planning stage; it contains the ideal flight path. If you used the Airborne QC extension option, Create a Survey Plan, to create the proposed survey plan, you should have such a database available. Otherwise, you need to prepare an XYZ file containing the proposed survey plan data and then import the file into a new database.
The selected lines in the survey database must have matching line numbers in the ideal line path database. This means that their line types, line numbers, and line versions do match. If selected lines exist in the survey database but not in the ideal line path database, an informational message will be displayed after the GX execution reporting the lines excluded from the quality control test.
The exception to the above rule is for "re-flights". The line number of re-flights is generally labelled using the number of the original line plus 1. Subsequent re-flights on the same line will be incremented by one, to a maximum of nine. For example, the first re-flight for line 11230 is labelled 11231, the 2nd re-flight is labelled 11232. The re-flight line numbers do not need to exist in the ideal line path database. As in the previous example, re-flights 11231 and 11232 will be tested against the line number 11230 in the ideal line path database.
Ideal lines are straight lines defined by two separate points. Therefore, this GX uses only the first and second set of (X, Y) coordinates to define the straight line. If there are dummy values in those two pairs of coordinates, a straight line cannot be defined, and the quality control test will not be carried out. The warning message displayed, if this occurs, will report the line number.
You can use the Edit Line tool to change the line numbers (type, number and version) in the ideal line path database. You can also use the Create Line tool to insert a new re-flight line into the ideal line path database.
Quality Control Specifications and Indicators
This GX allows for two separate specifications to be tested to determine whether the airplane flight line paths are acceptable or not:
1) |
At each reading location, the deviation of the flight lines from the ideal flight path must be less than the maximum deviation specified. |
2) |
The deviation of the flight lines from the ideal flight path may be greater than the allowed deviation for a distance less than the specified distance. |
You can apply one or both of these specification tests. To disable a test, leave the field(s) blank.
The GX creates a flag channel called Flag_Path in the current database. This channel contains numbers from -3 to 3 inclusive to indicate the result of the quality control test in terms of the flight line path.
Indicator Definition
Flag |
Description |
0 |
Flight path is acceptable. The flight path passes the test(s) applied. |
±1 |
Flight path fails the maximum deviation test. |
±2 |
Flight path fails the test on the allowed deviation over a given distance. |
±3 |
Both tests were run, and the flight path fails both tests. |
Positive and negative values indicate the different direction the actual survey deviates from the ideal flight line path.
Distance Calculation
When the specification of deviation over a specified distance is tested, the cumulative distance along the actual survey locations is used instead of the distance along the ideal line path.
