Split on Fiducial
Use the Split on Fiducial option, (geogxnet.dll(Geosoft.GX.Database.SplitLineAtFid;Run)*), from the Database Tools > Line Tools, to split a line into two lines at a specified fiducial.
The option is also available with the Gravity and Terrain Correction extension under the Moving Platform Gravity > Split Line menu.
Split on Fiducial dialog options
Line to split |
Input line name, will be shortened up to Fid. Script Parameter: SPLTLINE.IN |
New line |
Output line name, will get from FID and higher. Script Parameter: SPLTLINE.OUT |
Split at fiducial |
Fiducial at which to split the line. Script Parameter: SPLTLINE.FID |
Reset fiducial start values to zero |
After splitting the line, the fiducial of the first point can be preserved (default) or set to zero . Script Parameter: SPLTLINE. RESET_FID_STARTS[0-No, 1-Yes] |
It is often useful to split an existing line into parts. For example, an entire survey flight may be imported as a single line, then sub-divided into separate survey lines by displaying the survey trace and using the Split on Fiducial GX.
