Velocity Channel to Density Conversion
Use the option Database Tools > Database Utilities > Convert Velocity to Density, (geogxnet.dll(Geosoft.GX.VelocityToDensity.VelocityToDensity;Run)*), to convert a database channel containing seismic (P-wave) velocities into rock densities using one of the several published methods. The option is also available in the GM-SYS Profile Modelling extension.
Convert Velocity Channel to Density dialog options
        Input velocity channel  |
        Select the name of the existing channel containing velocity values to be converted. Script Parameter: VEL2DEN.CHANNELINPUT  |
        Velocity units  |
        Select the density units that the values in the output channel represent. Script Parameter: VEL2DEN.UNITSINPUT  |
        Output density channel  |
        Select the name of the new or existing channel that will contain the calculated density values. Script Parameter: VEL2DEN.CHANNELOUTPUT  |
        Density units  |
        Select the name of the new or existing channel that will contain the calculated density values. Script Parameter: VEL2DEN.UNITSOUTPUT  |
        Method  |
        Select the conversion method from the list. The valid range of velocities for each method is shown. Script Parameter: VEL2DEN.METHOD  |
        Dummy outside range  |
        Each conversion method is defined within a range of velocities (and corresponding densities). Check this box if you wish to dummy calculated values that fall outside of the defined range. Script Parameter: VEL2DEN.DUMMY  |
Published empirical relationships between seismic velocity and bulk density of various rock types are commonly used in processing seismic data (Gardner et al., 1974; Brocher, 2005). The Convert Velocity Channel to Density GX and Convert Density Channel to Velocity GX utilize 5th order polynomial expansions to approximate several of these relationships to less than 0.001 g/cm3 variance. Velocity to Density function and the inverse Density to Velocity function should match to within 4 significant figures.
Additional Methods
We have implemented Gardner, Nafe-Drake, and some other conversions as 5th order polynomial functions. The method names, coefficients, and appropriate velocity ranges are stored in the vel_density.csv file in the Oasis montaj distribution. Coeffients for Nafe-Drake, Christensen & Mooney, and Godfrey et al. methods are adapted from Brocher (2005). "Gardner" methods use coeffients derived from the tables in Gardner et al., 1974.
Additional Velocity-to-Density conversion functions may be added by editing the %USERPROFILE%\Documents\Geosoft\Desktop Applications \csv\vel_density.csv file. The conversion must be represented by a 5th order or lower polynomial, as described in the file header. Coefficients are appropriate for Velocity units of m/s and Density units of g/cm³ and unit conversions are performed by the GXs.
References
- [1] Gardner, G.H.F., Gardner, L.W., and A.R. Gregory, 1974, "Formation velocity and density - The diagnostic basics for stratigraphic traps", Geophysics, vol. 39, no. 6, pp. 770-780.
 - [2] Brocher, T.M., 2005, "Empirical relations between elastic wave speeds and density in the Earth's crust", Bulletin of the Seismological Society of America, vol 95, no. 6, pp. 2081-2092.
*The GX.NET tools are embedded in the geogxnet.dll file located in the \Geosoft\Desktop Applications\bin folder. To run this GX interactively (outside the menu), first navigate to the bin directory and provide the GX.NET tool in the specified format.  See the  Run GX topic for more guidance.
