Merge Voxels
Use the Voxel > Utilities > Merge Voxels menu option (geogxnet.dll(Geosoft.GX.VoxUtils.MergeVoxels;Run)*), to merge two existing numerical voxels to create a new voxel.
Merge Voxels dialog options
Voxel 1 |
Select the first voxel file to be merged. Script Parameter: MERGE_VOXELS.VOXEL1 |
Voxel 2 |
Select the second voxel file to be merged. Script Parameter: MERGE_VOXELS.VOXEL2 |
Output merged voxel |
Select the name for the merged voxel file. Script Parameter: MERGE_VOXELS.OUTPUT_VOXEL |
Horizontal cell size |
Optionally specify the horizontal cell size of the new voxel. If this is left blank, the output voxel cell sizes will be set to the minimum X and Y cell sizes in the Input voxel 1. The output Z cell sizes are set based on the original Z cell sizes in Input voxel 1, extending up and down as necessary, using the top and bottom Z cell size. Script Parameter: MERGE_VOXELS.CELL_XY_SPACING |
Horizontal Cell Size
If the horizontal cell size is not specified in the dialog, then the minimum of the X spacing or Y spacing of the first voxel is used as the spacing parameter.
Vertical Cell Size
The vertical spacing of the layers in the output voxel is based on the first input voxel. The top and bottom spacing of the first voxel is used for locations above and below the first voxel.
Merge Description
The first voxel will generally be resampled to match the horizontal spacing requirements, it will not be resampled if the horizontal spacing is equal to the horizontal spacing in both X and Y directions and the calculated resampled origin is equal to the current voxel origin.
The second voxel is then reprojected and resampled into the first voxel's coordinate system, and blending occurs where the volumes overlap.
The Blending Method
Once resampling of the initial voxel is completed, the resampled voxels consist of two sets of horizontal layers or slices, some of which may overlap, and so must be merged. The Blend method uses a blending function over the area of overlap so that transition across the overlap from one voxel to the other is smooth. The edge of the overlap zone typically has two parts; one bordering on voxel 1, and one bordering on voxel 2. The weighting at any location is calculated using the relative proximity of the two edges. For instance, if a position is equidistant between both edges, its value is the average of the grid values found at that point. A cosine function is used which varies smoothly from 0 to 1, and takes on a value of 0.5 at positions at the midpoint of the overlap.
Singular Points
Where the edges of Voxel #1 layer and Voxel #2 layer cross at a single point, the blending scheme breaks down, since by definition both grids are full owners of the point. In this case the average of the two grid’s values at the point is used.
Overlap
The Merge Voxels tool now checks the spatial extents of both voxels to see if they overlap, and informs you when they do not. Intersecting voxels occur when:
- The voxel bounds (the cube around them) intersect, or
- The voxel values intersect.
