Reproject a Voxel
Use the Voxel > Utilities > Reproject a Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.ReprojectVoxel;Run)*), to reproject a voxel that includes a projected coordinate system.
Reproject a Voxel dialog options
Input Voxel |
File name |
Select the voxel file to be reprojected. Script Parameter: VOXEL_REPROJECT.INPUT |
Coordinate system |
The Coordinate system entry is read-only and is automatically populated from the input voxel. |
Coordinate system units |
The Coordinate system units are read-only and are automatically populated from the input voxel. |
Output Voxel |
File name |
Specify the output voxel file name. A new voxel file will be created from the input voxel file, with a modified projected coordinate system. The extension ".geosoft_voxel is added automatically. Script Parameter: VOXEL_REPROJECT.OUTPUT |
Coordinate system |
The output Coordinate system is read-only and is automatically populated from the output voxel. To change the coordinate system, click the Modify Coordinate System button. The default is "Undefined"; however, once a coordinate system has been set, it will be remembered and populated on subsequent runs. Script Parameters:
The output Coordinate system units are read-only and are automatically populated from the output voxel. To change the coordinate system units, click the Modify Coordinate System button. The default is "metre"; however, once a coordinate system has been set, it will be remembered and populated on subsequent runs. The units apply to the horizontal and vertical coordinates of the voxel. When reprojecting a voxel into a coordinate system that uses different horizontal units, the vertical units are also scaled.
Script Parameter: VOXEL_REPROJECT.IPJ_UNITS |
[Modify Coordinate System] |
Click the Modify Coordinate System button to display the Coordinate System dialog. |
The Reproject a Voxel option creates a new voxel file from the input voxel file, with a modified projected coordinate system. The voxel cell sizes remain unchanged (except for scaling to account for a change in units) and the data is not re-sampled. The origin is altered in order that the output voxel is located at the same geographic location on the earth as the original however, the depth /vertical location of the voxel is not changed. The voxels rotation about the vertical axis is altered to ensure that the orientation with respect to north remains the same.
