Sample a Voxel
Use the Voxel > Utilities > Sample a Voxel menu option or the Section Tools > Sample Voxel to Database menu option, (geogxnet.dll(Geosoft.GX.VoxUtils.SampleFromVoxel;Run)*), to sample a voxel at X,Y and optionally Z locations. The new output data channel depends on the Z coordinate specification.
Sample Voxel to Database dialog options (no Z channel specified)
Voxel file
The voxel file to sample from.
Script Parameter: SAMPLEVOXEL.VOXEL
Interpolation method
Interpolation method to use (Linear/Nearest).
Script Parameter: SAMPLEVOXEL.INTERP_METHOD (L: Linear, N: Nearest)
Output data channel
Output sampled voxel array channel. The voxel is sampled along the X & Y trace vertically down to the maximum depth of the voxel. The depths are stored in the header of the extracted data array. The horizontal voxel cell is used as the sampling interval in depth.
Script Parameter: SAMPLEVOXEL.OUTPUT_CHANNEL
Topography channel
This scalar channel samples the surface of the Voxel. It is discretized to the voxel cell increment.
Script Parameter: SAMPLEVOXEL.TOPOGRAPHY_CHANNEL
Sample Voxel to Database dialog options (Z channel is a scalar)
Voxel file
Output data channel
The output sampled voxel channel is a scalar channel along the scalar X,Y,Z trace.
Sample Voxel to Database dialog options (Z channel is an array)
Voxel file
Depth array
Input depth array. The voxel will be sampled along the X, Y trace at the depth locations specified in this array.
Script Parameter: CDI.DEPTH_ARRAY_CHAN
Use negative depths down
If the Depth array is specified as elevations ( +ive Z axis up), check this box.
Script Parameter: CDI.NEGATIVE_DEPTHS_DOWN [0-No | 1-Yes (default)]
Elevation
Optional Topography. If supplied, prior to extracting the voxel values, this value will be added to the depth channel values to match the depth datum with that of the voxel.
Script Parameter: CDI.ELEVATION_CHAN
Output channel
Output sampled array channel.
