Window a Voxel
Use the Voxel > Utilities > Window a Voxel menu option (geogxnet.dll(Geosoft.GX.VoxUtils.WindowVoxel;Run)*), to subset an existing voxel to a new voxel.
Window a Voxel dialog options
Input voxel file
Select the voxel file to be windowed.
Script Parameter: WINDOW_VOXEL.INPUT
Output voxel file
Specify the name for the windowed voxel file.
Script Parameter: WINDOW_VOXEL.OUTPUT
Clip output to remove dummies
Check this box to remove full layers in X, Y and/or Z where there are no valid (non-dummy) data items.
Script Parameter: WINDOW_VOXEL.CLIP (0: No, 1: Yes)
Horizontal Windowing
Check this box to perform horizontal windowing. Horizontal windowing can be done using either a polygon file, or by specifying individually the limits in X and/or Y.
Script Parameter: WINDOW_VOXEL.HORIZONTAL_WINDOWING (0: No, 1: Yes, Default: 1)
To a polygon
Select this radio button to activate the controls for polygon file windowing.
Script Parameter: WINDOW_VOXEL.HORIZONTAL_MODE (0: To a polygon, 1: To ranges in X and Y, Default: 0)
Polygon file (*.ply)
Browse to the Geosoft polygon (*.ply) file to use to window the voxel.
Script Parameter: WINDOW_VOXEL.PLY
Mask values
Select whether to mask values inside the selected polygon or outside. Geosoft polygons can be created with both inclusive and exclusive polygons. Selecting outside produces the normal expected behaviour; only data values located within the polygon inclusion areas will remain after the windowing. Selecting inside reverses the normal behaviour.
Script Parameter: WINDOW_VOXEL.MASK (0: inside, 1: outside, default: 1)
Select this radio button to activate the controls for horizontal windowing using X and Y minimum and maximum values.
Minimum X, Y
Maximum X, Y
Select the ranges in X and Y to retain in the output voxel file. If a range is not specified (left blank), then no limit is applied; the range is left open.
Script Parameters: WINDOW_VOXEL.MINX, MINY, MAXX, MAXY
Vertical Windowing
Check this box to perform depth windowing. Depth windowing is done using specified limits in Z.
Script Parameter: WINDOW_VOXEL.VERTICAL_WINDOWING (0: No, 1: Yes, Default: 0)
Minimum Z
Maximum Z
Select the range in Z to retain in the output voxel file. If a range is not specified (left blank), then no limit is applied; the range is left open.
Script Parameters: WINDOW_VOXEL.MINZ, MAXZ
*The GX.NET tools are embedded in the geogxnet.dll file located in the \Geosoft\Desktop Applications\bin folder. To run this GX interactively (outside the menu), first navigate to the bin directory and provide the GX.NET tool in the specified format. See the topic for more guidance.
When subsetting a voxel:
dummy layers can be optionally removed from the output voxel.
the voxel can be windowed to the polygon file or along major axes.
the output voxel can be the inside or outside of the specified coverage.
the voxel can be windowed either as a vertical block or as a horizontal slab.
All the above operations maintain the proper registration and the integrity of the original voxel data.
If none of the three windowing operations are selected, then the output voxel file will simply be a copy of the voxel input.
