Set up IP Time Windows or Frequencies
This is a right-mouse-button contextual GX for inspecting or updating the time or frequency windows of an IP array channel.
Setup IP Time Windows or Frequencies dialog options
Domain type
Indicates if the data is time or frequency domain. This field is editable to allow you to input the information for older historical data.
Windows | Frequencies
Number of time of frequency windows. This is set to the dimension of the array.
Delay time | Base frequency
For time domain IP, the time delay before the first reading. For frequency domain, the base frequency.
Time windows | Frequencies
Expanded or concise list of the time/frequency values. The concise syntax is n x m interpreted as values (m) repeated n times .
The IP menu loads this contextual right-mouse menu item which only applies to array channels. If the time or frequency window information is imbedded in the array channel it will be loaded. For older data, not containing this information; you can input it using the same tool.
This is an interactive tool only, and hence does not have scripting parameters.
The format for the time windows has been standardized with that for the voxel cell sizes in VOXSTAT.GX, with the existing addition that if you do not have the full number specified, the last value is assumed to be repeated as many times as necessary so that all array elements have an assigned time window value.
Variable Cell Size Syntax
