Calculate Chargeability
Use the Calculate Chargeability option, (geogxnet.dll(Geosoft.GX.IP.CalculateChargeability;Run)*), to calculate the area under the IP decay curve during the off time.
Calculate Chargeability dialog options
IP channel |
Input induced polarization (IP) array channel name. This entry is mandatory. Script Parameter: IP_CALCUALTE_CHARGEABILITY.IP_CHANNEL |
Calculated chargeability |
Output chargeability channel name. This entry is mandatory; it will hold the area under the IP decay curve. Script Parameter: IP_CALCULATE_CHARGEABILITY.CHARGEABILITY_CHANNEL |
Normalize chargeability |
If the IP channel is already normalized by the primary voltage, simply leave this unchecked.
Script Parameters: IP_CALCULATE_CHARGEABILITY.NORMALISE [0 – do not normalize(default), 1 – normalize] IP_CALCULATE_CHARGEABILITY.NORMALISATION_TYPE [0 –voltage constant (default), 1 – voltage channel] |
Voltage channel or value |
Depending on the choice above, this is either the channel name for the primary voltage or a constant. Script Parameter: IP_CALCULATE_CHARGEABILITY.VOLTAGE_CHANNEL or IP_CALCULATE_CHARGEABILITY.VOLTAGE_VALUE |
The integrated chargeability (M) is an indication of the amount of potential energy stored within a chargeable rock. It is defined as the area under the curve (indicated in red) normalized by the voltage (Vm):
