Create Section(s) from Plan Map - Slices
Use this tab to plot a slice from a Voxel or 3D DXF, 3D Shapefile, or Geosoft Geosurface on a Plan or Section map.
Slices Tab
Vector Slices |
Plot 3D vector file slice |
Check to enable/disable the plotting of a 3D vector file slice on either a Plan or Section map.>>
The voxel slices are extracted along the central plane of the plan or section being plotted. For a plan map, this is the center elevation.
For 3D DXF vector files, the intersection of the DXF and the section (or plan) plane will be computed and a polygon feature class of that intersection will be added so that it displays correctly into the oriented data frame. There is also a Front & Back slice, corresponding to the front and back of the section thickness, respectively.
Since DXF files do not store any coordinate system information within the file, only DXF files whose coordinate system matches that of the drillhole project currently in use should be imported using this option. 3D Shapefiles do not get sliced, but the whole shape is projected on to the plane of the map.
- Creating Section(s) from Plan Map
- Creating Section(s) from Plan Map - Reference Grid
- Creating Section(s) from Plan Map - Topography
- Creating Section(s) from Plan Map - Profiles
- Creating Section(s) from Plan Map - Page Layout
- Creating Section(s) from Plan Map - Section Location
- Creating Section(s) from Plan Map - Plan View
- Creating a Section Plot
