Map Text Editor
The Map Text Editor enables you to add text to the currently selected map group, while you are in Edit mode. This text edit tool enables you to add multiple lines of text and specify the font attributes of the text.
Map Text Editor |
Text window |
Type your text in the Text window provided. You can add multiple lines by pressing the Enter key. |
[Font Properties] |
Click the Font Properties button to display the Font Attributes dialog. |
The Map Text Editor dialog can be resized, increasing the size of the Text window for easier viewing of your text. To increase the size of the Map Text Editor, using your cursor - hover over the bottom of the Map Text Editor dialog until your cursor changes to an arrow (
). Click your left mouse button and drag the bottom of the dialog down, until the window is an appropriate size.
