Create Master Grid
Use the Create Master Grid option (geogxnet.dll(Geosoft.GX.GridUtils.MasterGrid;Run)*), from the Grid and Image > Utilities menu to create a grid of any dimensions and populate it with a constant value. Once created, you will be prompted to edit the grid parameters, like cell size, rotation, coordinate system.
The option is also available in the GM-SYS 3D Tools > Grid Editing menu with the GM-SYS 3D Modelling extension.
Create Master Grid dialog options
New grid name
The name of the created grid
Script Parameter: MASTER_GRID.OUPUT_GRID
Grid points in X direction
The number of grid cells in the X direction
Script Parameter: MASTER_GRID.NX_INT
Grid points in Y direction
The number of grid cells in the Y direction
Script Parameter: MASTER_GRID.NY_INT
Constant grid value
The constant value to assign to every grid cell
Script Parameter: MASTER_GRID.CONSTANT_DVALUE
This process creates a grid of the supplied dimensions, with unit cell size, no rotation, and unknown coordinate system. Once the grid is created, you will be prompted to edit the grid parameters, like cell size, rotation, coordinate system.
