Bentley CONNECTION Client
The CONNECTION Client is a system tray application that manages authentication and authorization for Bentley applications and cloud services. Once you securely sign in using your Bentley account, you gain access to licensed products available to your organization.
Additionally, the CONNECTION Client serves as a gateway to Bentley's cloud services, portals, and analytics. By signing in, you can download software updates, receive relevant notifications, and access additional features available to Bentley users.
Accessing the CONNECTION Client
To access the CONNECTION Client, follow these steps:
Locate the CONNECTION Client icon
in your system tray. -
Click or right-click the icon.
Select Open from the pop-up menu.
In the CONNECTION Client dialog, enter your Bentley email address and click Next.
Your signed-in status will be indicated by the updated CONNECTION Client icon
in the system tray, along with the additional "Connect Center" option in the pop-up menu:
Once signed in, CONNECTION Client options can be accessed via the drop-down menu next to your Bentley user account.
Select the desired version and click Install Selected to begin the download and update process.
The system tray pop-up menu
The drop-down menu within the CONNECTION Client
Entitlements– Displays previously launched products that have communicated with Bentley Connect.
Checkout License– Allows eligible products to be checked out for offline use.
Product Status – Shows available products within your installation.
Signing In
Updating the CONNECTION Client
If a new version is available, an orange button will appear in the Updates section.
Bentley Licensing Tool
To review your Bentley entitlements, use the License Tool option from either:
This tool, installed with the CONNECTION Client, provides activation functionality and product information for applications that support the Subscription Entitlement Service (SES).
The Bentley Licensing Tool includes three tabs:
For more details, open the
Signing Out
To sign out of the CONNECTION Client, select the Sign Out option from either:
If you sign out while using Oasis montaj, a warning message will appear with guidance on the next steps:
Offline Licensing via CONNECTION Client
Provided you are authenticated through the Seequent Connector, you can maintain access to your licenses for up to 90 days while offline, This extended offline capability allows continued use of applications such as Oasis montaj and Target.
Bentley applications offer a different offline experience depending on user setup and administrator configurations.
Standard Offline Grace Period
After signing in to the CONNECTION Client and loading entitlements, you can work offline for up to 7 days.
During this grace period, Bentley applications rely on the last known entitlements.
After 7 days, you must reconnect to the internet and sign in again to continue using the applications.
Extended Offline Access
For longer offline scenarios (e.g., travel, remote work, secure environments), administrators can:
Check out licenses via the Entitlement Management Portal
Generate a .BELIC license file tied to a specific machine name
Users then import the file using the Bentley Licensing Tool
Checked-out licenses allow 24/7 usage until manually checked back in
Offline Mode Settings
If offline mode is enabled by your administrator:
You can continue working without interruption during the grace period.
If offline mode is disabled:
You must be online and signed in to launch Bentley applications.
The CONNECTION Client icon will display an offline status, and will automatically sign in upon reconnection.
Disconnected Usage
If your internet connection is lost and entitlements cannot be verified, an error message may be displayed:
Verify your product entitlements with your organization administrator.
Use the provided link to contact Support for assistance.
