Latitude Correction
Use the Latitude Correction option (AGLATCOR GX) to calculate latitude corrections.
The option is available with the Gravity and Moving Platform Gravity extensions under the following menus:
- Gravity > Gravity Corrections
- Moving Platform Gravity > Corrections by Steps
Calculate Latitude Correction dialog options
The earth’s gravity field is stronger at the poles than at the equator (by about 5,100 mgals) as a result of several effects. One of these effects is the earth’s ellipsoidal shape. The earth’s surface gets progressively closer to the centre of mass at higher latitudes. As a result, the attraction at the poles is greater than at the equator. The variation in gravity with latitude is defined in terms of gravity on the surface of the spheroid. The latitude correction requires the theoretical gravity at the station location on the earth's spheroid. There are five formulas provided for calculating the latitude correction:
The 1930 International Gravity Formula [1] based on the International Ellipsoid used with the Potsdam Ellipsoid:
The 1967 International Gravity Formula [1] based on the Geodetic Reference System used with the IGSN 71 ellipsoid:
The 1976 Telford formula [2]:
The 1980 (Moritz) formula [1], [4] (which led to the World Geodetic System 1984):
The 1980 (Telford) formula [3]:
Where:
Theoretical gravity in milligals (latitude correction)
Latitude of the station
The first time the latitude correction is executed, the five formulas defined using Oasis montaj expressions are saved in the file "Gravity_Latitude.lst" located in the folder %USERPROFILE%\Documents\Geosoft\Desktop Applications \etc.
If you would like to provide alternate equation(s), append them in the "Gravity_Latitude.lst" file.
Each expression should be defined on one line and should consist of a unique name followed by the complete expression using the following syntax:
Where:
Simply a conversion from degrees to radians
LatitudeCorrected
The output gravity channel
InputGravity
The input gravity channel
<latitude_correction_equation>
The custom equation; gets saved in the latitude correction channel
References
- [1] Richard J. Blakely, Potential Theory in Gravity and Magnetic Applications, (Cambridge: Cambridge University Press, 1996), pp. 135-136.
- [2] W. M. Telford et al., Applied Geophysics, (Cambridge: Cambridge University Press, 1976), p. 17.
- [3] W. M. Telford et al., Applied Geophysics, (Cambridge: Cambridge University Press, 1980), p. 10.
- [4] H. Moritz, "Geodetic Reference System 1980", Bulletin Géodésique, vol. 54, no. 3 (1980), pp. 395-405.
- [5] M. Dentith and S.T. Mudge, Geophysics for the Mineral Exploration Geoscientist, (Cambridge: Cambridge University Press, 2014), pp. 100-102.
