Edit Selected Lines (EDITLINE GX)
In the database spreadsheet window, select (highlight) the line header (the left-most channel header). Right-click the line header to open the Line/Group context menu:
- Use the Edit all Selected Lines option (EDITLINE GX) to edit information for all selected flight lines. This is useful when updating line types, flight numbers, or dates across a group of lines.
Edit all Selected Flight Lines dialog options
Line type |
Select the line type from the list. If left blank, the type remains unchanged. Script Parameter: EDITLINE.TYPE |
Date (yyyy/mm/dd) |
Enter the date in YYYY/MM/DD format. If left blank, the date remains unchanged. Script Parameter: EDITLINE.DATE |
Flight number |
Enter the new flight number (integer). If left blank, the flight remains unchanged. Script Parameter: EDITLINE.FLIGHT |
If any fields are left blank, their corresponding parameters will not be changed.
The process will stop if the new name of a selected line already exists—lines processed up to that point will be updated.
Group lines are not affected by these operations.
