Gaussian Filter
Use the Gaussian option to apply a Fast-Fourier Transform Gaussian filter to a channel.
Gaussian filter options
Standard Deviation of function
(in ground units)
Standard deviation of function (in ground units).
Script Parameter: FFTGAUSS.STDDEV
Low or High Pass Filter
Select "Low" or "High" Pass filter (Default is Low)
Script Parameter: FFTGAUSS.PASS
The Gaussian filter is another smooth filter that is often used for low-pass or high-pass applications.
Gaussian Filter
Parameters:
k0 Standard deviation of the Gaussian function in cycles/ground_unit (similar to a cutoff except that the function amplitude at this point is only 0.39).
0/1 Specify 0 or 1 for residual or regional, respectively.
