Vertical Integration Filter
Use the Vertical Integration option to apply a Fast-Fourier Transform Vertical Integration filter to a channel.
Vertical Integration filter options
There are no user-defined parameters for this filter.
Calculates the vertical integral of the input transform. This is the inverse of the vertical derivative. The zero wavenumber is set to 0.
L(w) = w -1
