Grid Data - Direct Gridding
Gridding refers to the process of interpolating data onto an equally spaced “grid” of cells in a specified coordinate system. For an introduction to gridding and a summary of the different gridding methods click here.
Direct Gridding
The direct gridding method creates a grid from data without using any interpolation. It is intended for use with highly sampled data and it provides a quick gridded view of it. When the input database is very large and the gridding process may become lengthy, it can be used to quickly produce the first draft grid for inspection. For over-sampled data such as LiDAR, GPR, or seismic data, it can be the preferred option.
The method simply places in each grid cell the average (or the minimum or maximum value) of the data that populates it. In the first case, the data within a cell is weight-averaged relative to their proximity to the grid node. No other processing is performed on the data (e.g., iterative calculations or splinning); cells that are void of data points remain blank.
Use the Grid Data option from the Grid and Image > Gridding menu to grid data using the direct gridding method.
ClosedExpand to view other menus where this option is available:
Radiometric Processing:
  • RPS > Plotting > Grid Data
UXO-Marine:
  • UXO-Marine Sonar UtilitiesGrid Data
Direct Gridding Options
Data to grid
Select the database channel to grid. To specify an array element, append to the channel array name the element index in square brackets. For example, Chan[1] would indicate the second element of the array channel "Chan".
Script Parameter: DIRECT_GRIDDING.CHANNEL
Output grid
Provide the name of the output grid file. This field is auto populated based on the active database and the selected channel to grid; however, you can override the default.
The default output grid format is selected automatically as the output file type. The type can be controlled using the browse dialog, which is accessible from the [...] button.
 Script Parameter: DIRECT_GRIDDING.GRID
Gridding method
The current gridding method is displayed.
Script Parameter: GRIDDING_TOOL.METHOD [4: Direct]
Cell size
Specify a cell size for the output grid. This field is auto-populated with the calculated default grid cell size and rounded to the nearest ten or hundred:
Script Parameter: DIRECT_GRIDDING.CELL_SIZE
Extents and Data
Spatial Extents
Grid extents
(X min, Y min,
X max, Y max)
Define the spatial limits of the area to be gridded. By default, these fields are set to the full extents of the current X & Y channels of the active database in order to include all the data in the database:
X min, Y min: the ground coordinates of the first grid point at the bottom left corner of the rectangular grid area (by default, the minimum limits of the input data file are used).
X max, Y max: the ground coordinates of the last grid point at the top right corner of the rectangular grid area (by default, the maximum limits of the input data file are used).
To grid a subset of the data, enter the limits of the bounding rectangle, or press the Draw Extents button to interactively define the boundary extents – the output grid coverage will extend to these limits.
Script Parameter: DIRECT_GRIDDING.XY
[Draw Extents]
Press this button to interactively define the grid boundary extents: in the Grid Preview pane, use the mouse to click & drag to draw a box, then release the mouse cursor to accept the final size of the box. The X & Y values will be updated in the Grid extents fields, and the preview window will be refreshed to show the newly defined extents.
  • You can draw the box in any of the four possible ways (e.g., from bottom left to top right).
  • [Reset Extents]
    Press this button to reset the grid extents to the initial state of defaults for the active database.
    The Grid Preview pane (when Auto-refresh is enabled) will be updated to reflect the change; however, the zoomed state (in/out) of the grid preview will not be affected.
    Data Filtering
    Mask channel
    Select a channel from the drop-down list to act as a mask.
    Only database channels that have the class property set as "MASK" are listed. Additionally, string channels and channels with array size greater than 1 are omitted from the list.
    The data values in the selected Data to grid channel with corresponding dummy (*) values in the Mask channel will not be used in the gridding process.
    The X & Y values will be updated in the Grid extents fields to reflect the masked data, and the generated masked grid (with the correct extents) will be automatically rendered in the Grid Preview window (the Auto-refresh option must be selected).
    Script Parameter: DIRECT_GRIDDING.MASK_CHANNEL
    Interpolation
    Direct
    Cell value
    Individual grid cell values are assigned using the select statistic on all data values falling within that cell. The following options are available:
    • minimum value
    • maximum value
    • mean value
    • number of (valid, non-dummy) items in a cell
    You can create a grid of the density of sample locations, rather than the value recorded at each location. This gridding option is useful for determining the spatial distribution of highly sampled data and enables you to easily identify areas which are undersampled.
    Script Parameter: DIRECT_GRIDDING.GRID_VALUE [0: minimum, 1: maximum, 2: mean, 3: number of items, Default: 0]
    Set zero values to dummies
    This option becomes enabled when the Cell value option is the “number of items in a cell”.
    If checked, the cells for which no data values were found are given dummy values, so they won’t show up in the Grid Preview pane or when the grid is displayed from the Project Explorer.
    Script Parameter: DIRECT_GRIDDING.DUMMY_ZEROS [0: No, 1: Yes, Default: 1]
    [Restore Defaults]
    This button remains disabled until any of the fields default values are changed. Press the button to reset the gridding parameters to the initial state of defaults for the active database.
    When Restore Defaults is clicked:
    The following parameters are reset to their default values:
    • The cell size value
    • All the parameters on both the Extents and Data and Interpolation tabs
    • Only the parameters for the current gridding method are affected.
    The following parameters are not reset:
    • The data to grid selection
    • The output grid file name
    • The gridding method
    The Grid Preview (with Auto-refresh enabled) and Variogram panes will be updated to reflect any parameters changes; however, the zoomed state (in/out) of the grid preview will not be affected.
    [Run in background]
    Gridding can be a resource-intensive task. The duration can range from minutes to hours, depending on the size of the dataset. By choosing the Run in background option, you can execute the gridding process asynchronously, allowing you to continue using Oasis montaj for other tasks while the gridding is underway. Multiple instances of the gridding process can run concurrently in the background, whether they are for the same database or different ones.
    When you press the OK button with the Run in background option checked:
    An Oasis montaj command-line window (OMS) will open and run in the background on the taskbar until the gridding task is complete. Oasis montaj becomes available immediately after the OMS console window is launched. Do not close the console window before the process finishes — this will cancel the gridding, and no output grid file(s) will be produced. When the gridding process is complete, the console window will close automatically.
    In the current Oasis montaj project, in the Project Explorer:
    • You can monitor the progress of your gridding while working on other tasks.
      The progress of the gridding is monitored, and the status (e.g., processing, completed, failed, cancelled) is visually indicated in the Jobs tab. A new node is appended to the tab, and entries for each of the output files are created under this node in the tree.
    • As the gridding process for the selected database channel completes, the output grid is automatically added to the Grids node in the Data tab.
      You can double-click on the job node in the Jobs tab to initiate a re-run of the gridding using the previously set parameters. You also have the option to adjust these parameters before starting the process again.
    Closing the project (or the Oasis montaj instance) while background gridding is in progress will display a confirmation prompt. If you choose to close the project while the oms.exe is running in the background, the process will continue to execute to completion.
    The selection state of the Run in background option is retained on subsequent runs of the gridding tool in the same project.
    Once a gridding task is executed, the gridding options are retained when switching between different databases. The Grid Data tool will recall the previous gridding parameters associated with the current database, regardless of whether gridding tasks have been performed on different databases since.
