How to Run a GX or GX.NET Tool
Use the Project > Run GX menu option (or click the Run GX icon
on the Project Explorer toolbar) to open the Run GX dialog and run a GX.
You can run only the GXs for which you are licensed.
Run GX dialog options
GX file /entry |
The name of the GX or GX.NET tool you want to run. Refer to the instructions below for details on how to execute a GX or GX.NET tool.
Click the button to open the browse dialog. By default, the tool will search in the following folder: To Run a GX File:
To Run a GX.NET Tool: GX.NET tools are embedded in
The folder selection is retained on the subsequent run of the tool. When running a new GX/GX.NET, if you are prompted with an error message, click the browse button and ensure the tool is searching in the right directory (i.e., "gx" or "bin").
[History] |
If the GX/GX.NET you want to run has been previously executed from this dialog (in the current project), click the History button, and the dialog switches to "history" mode. The GX file/entry becomes a drop-down list, and you will be able to select the GX entry from the history of files that were previously run. The files are displayed with their full paths and names in the list.
Click OK to run the selected GX/GX.NET file. |
