Apply View Mask
Use the Map Tools > Masking > Apply View Mask menu option (VIEWCLIP GX) to reset the clip area of a view to a polygon mask file.
Apply View Mask dialog options
Clip polygon file (.ply)
The name of the clip polygon file.
Script Parameter: VIEWCLIP.FILE
Map view
The map view on which to apply the clip mask
Script Parameter: VIEWCLIP.VIEW
Clip all groups
Force all the groups in the view to be clipped.
Script Parameter: VIEWCLIP.FORCE
After changing a view clip area, groups within the view can be clipped to the view clip limits by setting their clip attributes. To do this, select the group to be clipped, press the right mouse button, and select the "clipped" option in the pop-up menu.
Polygon Mask Files
  • Polygon files are ASCII text files with the default .ply extension.
  • Each file contains a list of X,Y coordinates defining one or more polygons.
  • Files can include any number of polygons, each with any number of vertices.
  • The first and last points of each polygon are assumed to be connected.
File Structure Guidelines:
  • Each polygon begins with a line starting with poly # (with p or P in column 1).
  • Comment lines begin with / in column 1.
Creating Polygons Interactively
You can also create clip polygon files interactively using the digitising tools available in the Map Tools menu.
Example of a single polygon file:
/ Sample single polygon file
poly 1
1376027.6061 6178025.9399
1382846.3129 6178025.9399
1382846.3129 6182748.8182
1376027.6061 6182748.8182
Example of a three polygon file:
(Note the exclusive following the poly 3 entry; this indicates exclusive regions or holes in polygon sets.)
/ Sample three polygon file
poly 1
1375594.6724 6181961.6718
1378706.3838 6181961.6718
1378706.3838 6184716.6842
1375594.6724 6184716.6842
poly 2
1375757.0225 6178629.4188
1379896.9516 6178629.4188
1379896.9516 6181174.5254
1375757.0225 6181174.5254
poly 3
exclusive
1380546.3523 6175926.8828
1384550.9896 6175926.8828
1384550.9896 6179022.992
1380546.3523 6179022.992
