Window X ,Y to Polygon Mask
Use the Database Tools > Window Data > Window X ,Y to Polygon Mask menu option (WINXY GX) to mask the X and Y channels to the area defined by a polygonal mask file. This restricts all subsequent map-based processing to data within the defined region.
Window X ,Y to Polygon Mask dialog options
Mask polygon file
Specify the ASCII file defining polygon masks.
Script Parameter: WINXY.MASK
Dummy inside or outside
Indicate whether you want to dummy inside or outside of the polygon mask area.
Script Parameter: WINXY.DUMMY
This GX is used to limit the X and Y coordinates to the part of the area to be plotted. All MAP based processes will use the X and Y channels as the plotting coordinates. By dummying those parts of the area outside the area of interest, all plotting will be restricted to the defined area.
A copy of the original X and Y channels is saved to __X and __Y (if these channels do not already exist). Future windowing operations will use these channels as the source channels. (If running interactively, a warning message is displayed asking whether you wish to overwrite the backup channels).
Polygon Mask Files
  • Polygon files are ASCII text files with the default .ply extension.
  • Each file contains a list of X,Y coordinates defining one or more polygons.
  • Files can include any number of polygons, each with any number of vertices.
  • The first and last points of each polygon are assumed to be connected.
File Structure Guidelines:
  • Each polygon begins with a line starting with poly # (with p or P in column 1).
  • Comment lines begin with / in column 1.
Creating Polygons Interactively
You can also create clip polygon files interactively using the digitising tools available in the Map Tools menu.
Example of a single polygon file:
/ / Sample single polygon file /----------------------------
poly 1
1376027.6061 6178025.9399
1382846.3129 6178025.9399
1382846.3129 6182748.8182
1376027.6061 6182748.8182
Following is an example of a three polygon file:
/ / Sample three polygon file /---------------------------
poly 1
1375594.6724 6181961.6718
1378706.3838 6181961.6718
1378706.3838 6184716.6842
1375594.6724 6184716.6842
poly 2
1375757.0225 6178629.4188
1379896.9516 6178629.4188
1379896.9516 6181174.5254
1375757.0225 6181174.5254
poly 3
1380546.3523 6175926.8828
1384550.9896 6175926.8828
1384550.9896 6179022.992
1380546.3523 6179022.992
